engine swap out in 880
I'm confused
01-14-2005 11:53:21
I was wondering if you can put motors out of bigger diesels in a 880. I know where there is a 478ci out of a 2150 and was wondering if it will bolt in? thank you.
A.P.
01-14-2005 12:25:35
 Re: engine swap out in 880 in reply to I'm confused, 01-14-2005 11:53:21
You can put anything you want in it if you are determined enough and willing to replace or do major modifications to the front frame (and modify sheet metal). I suggest using a 310 with a turbo if you want a reasonably easy swap. I would use a 3208 Cat or 6V92T Detroit before trying the 478 in an 880. The 478 might wind up being a "Monster Garage" project. It certainly would be mean.
