Super MTA (Steel Flywheel) V8 Puller
Mez25
01-14-2005 08:06:08
I need to find a steel flywheel for a Super MTA for a V8 tractor. I want to remove the cast one from the tractor and need some information on an individual that may have one for sale or who knows where I could have one made. Any information would be appreciated. Thanks
exmpuller
01-17-2005 19:32:18
 Re: Super MTA (Steel Flywheel) V8 Puller in reply to Mez25, 01-14-2005 08:06:08
I have a steel flywheel that I was going to run for M ss. We figured that we were getting 475hp out of it at 4500rpm. We also run a ford clutch.
I would sell it complete or I can provide you the place where I got mine. Let me know.
donkster
01-16-2005 16:40:41
what v8 engine are you using? it will have to be a flywheel for that engine. and it will have to be balanced for it.no stock flywheels.you are asking for trouble. i have a v8 mta. alot of time and thought was put into the clutch,input,and flywheel.
firefarm
01-16-2005 19:43:40
 Re: Super MTA (Steel Flywheel) V8 Puller in reply to donkster, 01-16-2005 16:40:41
How many RPMs are you running your V8. Do you ever use the TA while you are pulling? I run a 560 with COATPA and was haven"t had the guts to try to throw the TA forward in 4th yet.
firefarm
01-16-2005 14:36:10
Are you looking for a steel flywheel for the V8 that you are putting in the MTA? If that is what you need, order it from Jegs or Summit.
