will a 88 motor go in a 77 oliver
lafngas
01-14-2005 07:35:32
I have a good 88 motor just rebuilt will it fit my 77 what all is involved
Bigmotors
01-14-2005 21:11:50
 Re: will a 88 motor go in a 77 oliver in reply to lafngas, 01-14-2005 07:35:32
47-88, Where is the 1947-88 located? How Much$$$
Drop me a e-mail.
Thanks!
madmassey
01-14-2005 18:07:35
sure a 88 engine will bolt right in. All that you need to do is shorten the drive shaft. Took my boys 77 out to Wichita, entered it in division three, when they inspected the motor the guy kinda scratched his head and went over to his 88, came back and looked at it again and said ( heck, thats a 88 engine} you can't pull it because it's not the right block length. only difference between a 77 and 88 is the 88 block is a inch longer, quater inch more stroke piston size is the same.
Patches
01-14-2005 19:37:41
 Re: will a 88 motor go in a 77 oliver in reply to madmassey, 01-14-2005 18:07:35
Now-now madmassey, you did do well in the exhibition didn't you?????
madmassey
01-15-2005 07:35:13
 Re: will a 88 motor go in a 77 oliver in reply to Patches, 01-14-2005 19:37:41
Patches, are you ready for the big one? I have the massey all torn down, going to try to get it back together today for I can pull at carthage.Farmer Jake has both of his olivers ready! I talked to richard last nite, told him he needs to get the money from the arena onwer for the trophies, I will pick them up Wed while Im in springfield.
Patches
01-15-2005 08:48:08
 Re: will a 88 motor go in a 77 oliver in reply to madmassey, 01-15-2005 07:35:13
Everything is a go and on schedule, all issues are taken care of and accounted for, just waiting on the weekend. Praying for good weather and NO CHICKENS. LOL
ejr
01-14-2005 16:26:50
I had a 77 with a 1800 gas motor stuffed in it.That will give you a pretty good ride.
spinninNgrinnin
01-18-2005 12:50:13
 Re: will a 88 motor go in a 77 oliver in reply to ejr, 01-14-2005 16:26:50
How about a 77 with a 552 stroker in 3500lb,that would be fun,perhaps road gear would be in order.
mr oliver
01-14-2005 13:13:34
It will bolt right in.You will have to shorten the shaft between bellhousing and rearend about a inch. What we did is cut the 77 shaft in half cut a inch out and slide another pipe inside to keep it straight and welded it back together then you wont have to mess with the splines.
lafngas
01-14-2005 13:32:59
 Re: will a 88 motor go in a 77 oliver in reply to mr oliver, 01-14-2005 13:13:34
Will the shaft from the 88 work i have it if not that sounds like an easy fix Thanks for all the help also will the exahust exit in the same place and do i have to move the radiator forward any how much more hp will this motor be over a 77 Thanks for all the help guys not a big ollie guy more into farmalls and molines
Mr oliver
01-14-2005 19:04:21
 Re: will a 88 motor go in a 77 oliver in reply to lafngas, 01-14-2005 13:32:59
exhaust will come out same hole. You do not have to move radiator but you will have to find a fan with small blades on it to fit in the shroud or take the shroud off.
Patches
01-14-2005 12:09:16
Sure you can, it will fit,just don"t try and pull it at a NATPA pull, just ask MadMassey, he can tell you all about it.
Goldsburg
01-14-2005 11:00:44
Why not go ahead and put a 310 Waukesha in instead? You could go turbo diesel (310) or go with the 7 main gas (VRG283). Either will fit fairly easily!
There have been several 7 main motors put into 77 chassis in my area!
Regards,
Goldsburg
[email protected]
lafngas
01-14-2005 11:26:13
 Re: will a 88 motor go in a 77 oliver in reply to Goldsburg, 01-14-2005 11:00:44
i have this 88 with over bore kit milld head and port work i did 2 years never got a tractor to put it in i traded for the 77 with a bad motor just got to woundering if it would work
family tradition
01-14-2005 09:21:28
we did one of these about 20 yrs ago and if I remember right, it was a direct bolt in. someone correct me if i am wrong
family tradition
01-14-2005 09:21:22
lafngas
01-14-2005 09:33:31
 Re: will a 88 motor go in a 77 oliver in reply to family tradition, 01-14-2005 09:21:22
did it work good i know i can get a 77 lighter than the 88 just thought cheap h.p
47 - 88
01-14-2005 17:08:48
 Re: will a 88 motor go in a 77 oliver in reply to lafngas, 01-14-2005 09:33:31
If you find a 1947 88 you can get it just as light as a 77 if not lighter .I know where there is one that might be for sale.
ol George
01-14-2005 19:42:33
 Re: will a 88 motor go in a 77 oliver in reply to 47 - 88, 01-14-2005 17:08:48
I would stick with the 77 if lighter is what you want. There are more ways to do that conversion than are often thought of and it sure does make easier horsepower.
ejr
01-15-2005 11:27:08
 Re: will a 88 motor go in a 77 oliver in reply to ol George, 01-14-2005 19:42:33
And what would that way be?
