Suggestions on pulling clutch for Oliver 88
torquenut
01-13-2005 19:17:46
Okay, looking for suggestions on clutch for Oliver 88. Tractor should make around 120 hp.
s88puller
01-14-2005 05:28:19
 Re: Suggestions on pulling clutch for Oliver 88 in reply to torquenut, 01-13-2005 19:17:46
You could talk to Marietta Joint and Clutch (740)-376-9977 they can get any kind of clutch for anything. If you want to go with an 880 clutch they can get them, but we had them fix us up with a button clucth for our 770 and our super 88 and they do not slip period.
s88puller
01-14-2005 05:27:43
You could talk to Marietta Joint and Clutch (740)-376-9977 they can get any kind of clutch for anything. If you want to go with an 880 clutch they can get them, but we had them fix us up with a button clucth for are 770 and our super 88 and they do not slip period.
Cody
01-13-2005 19:35:01
Get you an 880 industrial clutch. It is 11" and it will bolt onto the outer bolt holes olf your flywheel. It will hold your engine just fine. I ran one behind a 125HP 88 for 3 years with no problem.
torquenut
01-14-2005 04:11:21
 Re: Suggestions on pulling clutch for Oliver 88 in reply to Cody, 01-13-2005 19:35:01
Cody, where is a good place to purchase such an animal?
Cody
01-14-2005 14:47:09
 Re: Suggestions on pulling clutch for Oliver 88 in reply to torquenut, 01-14-2005 04:11:21
Call me, 931-212-3602, I can get you one from Hy-Capacity. It wans't that expensive and I think he could have gotten a button disk, but they are harder to slip out of the hole. I had to send them my old disk as a core.
