Aluminum Rods
jdtruble
01-13-2005 06:28:22
Has any one ever made a set of rods out of aluminum? I am thinking of trying to make some, might try 6061 T6 aluminum. any body have any thoughts on this.
Carney
01-13-2005 07:00:03
 Re: Aluminum Rods in reply to jdtruble, 01-13-2005 06:28:22
Use 7075-T6, 6061 is not strong enough and may "work harden" and break. 7075 has about 2x the tensel strength but costs 2x as much. Some alcohol supers run 7075 with no treating afterwards. There is a lot of geometry involved in makeing a set. to figure price on the material figure size, cubic inches x .101.$5.50 for an approx price. Ex 2"x4"x12" = 96 x .101 = 9.696 x $5.50 = $53.33 per foot. I am almost done makeing a set, only took twice as long as I figured on a cnc (crank n crank) bridgeport mill.
Brad Gray
01-14-2005 07:01:16
 Re: Aluminum Rods in reply to Carney, 01-13-2005 07:00:03
A better material to use is 2024 t6 Have you ever seen what 7075 does over about 200 degrees? It looses strength fast. 2024 has a little less tensile at room temperature, but stays steady as the temperature rises.
LW
01-13-2005 19:49:51
Use 7075 Fortal its even stronger already heat treated and can be bought off e-bay ,contact Jim at the Mousebar materials, about $3 lb. manufactured cost about 12$ a lb. he buys all the drops, this is the military helicopters frames and motor mounts etc. are made from.
big jugs
01-13-2005 17:16:41
Carney, are you making these and the billet camshafts for your brothers in Colfax? Are you taking pictures so you can go back and show them step-by-step procedures of a "professional" does it? Hey, if you got the money, I could use another 20 bucks!
PS
01-14-2005 14:51:35
 Re: Aluminum Rods in reply to big jugs , 01-13-2005 17:16:41
Got to save the cash, need it for materials, making a new counter weighted crank, alum. rods, new cam, new design head and header. Go or blow, might just turn over 7000 this time. Better bring a broom, bucket and floordry to pick up the peices
Carney
01-13-2005 17:30:03
Send her over, it's thursday night, maybe you can get a little closer to that first million
big jugs
01-13-2005 18:01:35
 Re: Aluminum Rods in reply to Carney, 01-13-2005 17:30:03
Shoot! It is thurs. isn't it! Will there be enough heat out there in Captains shop? What do you mean first million? I'm working on the second. Gave up on the first, was too hard to make!
Cody
01-13-2005 15:35:15
Use an 880 industrial clutch. It is 11" and it will bolt right onto the outer bolt holes of your flywheel. It will hold you engine just fine.
