Question for WTW Deere Pullers
Jon B
01-12-2005 11:24:20
In your opinion, which of these tractors would yield more power: Both are 1948 A's. Tractor #1: 5.5 bore with .125 over aluminum pistons, 7.25 stroke, stock head and manifold, stock cam, distributor ignition, DLTX 51 carb. Tractor #2: power block with 6" bore, 6.75 stroke, heisler head with porting and oversize valves, heisler intake, stock cam, distributor ignition, DLTX 71 carb. Neither have PTO in them so i am unable to dyno. Both are for sale, and I am trying to decide. Thanks.
WTW
01-12-2005 13:29:41
 Re: Question for WTW Deere Pullers in reply to Jon B, 01-12-2005 11:24:20
The stroker tractor yields 360 cubic inch, the Power-block tractor has 382 cubic inch. with the correct tuning one will pull about the same as the other because the stroker tractor will make more power with less cube. The thing you have to look at is the potential the Power-block and Heisler head tractor have to offer when you put a decent size stroker crank behind that package someday down the road, you will have much more potential to work with. If both tractors were priced somewhere close to each other it would be the best to go for the Power-block and Heisler head tractor as the two items together have allot of potential and are worth quit a bit for just parts. A stroker crank will cost less than what the Power-block and Heisler head can be purchased for. Good luck on what ever you decide, DW
torquenut
01-12-2005 12:20:22
Yes, the second definately esp. if little price difference between the two. You can ad that stroke later.
jr4430
01-12-2005 11:26:58
you want the 2nd one.
