Re-using head gaskets
Kenny Chinsey
01-11-2005 21:01:51
Can you reuse a Case/IH factory head gasket once it has been torqued down and test run on an engine or should I buy a new one?
Thanks
topsarg
01-12-2005 05:04:39
 Re: Re-using head gaskets in reply to Kenny Chinsey, 01-11-2005 21:01:51
In the past, I have reused the installed and tested head gaskets with no problems at all. Most applications requires a retorque after a short run in time anyway. I did coat the gasket with a thin layer of copper coat. Saves buying another set of gaskets.
