More electric pumps.
Ohio H
01-10-2005 17:09:05
What can i use for an inlet/outlet for a farmall. I have an old waterpump, gutted and welded a cover where the pully would be. Would this work for an inlet with an electric pump. then use the stock outlet. Thanks.....H
Ohio H
01-10-2005 17:12:13
 Re: More electric pumps. in reply to Ohio H, 01-10-2005 17:09:05
If anyone can post a pic. or send me one, of your set up, would be greatly appreciated. Thanks.....H
Kenny Chinsey
01-10-2005 17:29:11
 Re: More electric pumps. in reply to Ohio H, 01-10-2005 17:12:13
Are you running any hard block? I am just speculating, but the coolant flow into the block and or head may be compromised if a flow pattern is not established. If you just put an inlet into this modifed pump housing and pump water in, more of it may go straight up and out to the radiator than into the head or block. Also, it will probably make a difference if you are running a thermostat or not. These are some of the things that I would think of if I were trying your type of setup. Good luck.
Ohio H
01-11-2005 09:50:47
 Re: More electric pumps. in reply to Kenny Chinsey, 01-10-2005 17:29:11
No hard block, using thermostat and factory outlet, original radiator.
