Billet Camshafts
Carney worker
01-10-2005 16:22:35
I am tooling up to make a run of billet cams on needel berrings for olliver 88 blocks, available as a turned blank or a finished cam, profile of your choice. If there is any intrest in this please let me know.
cshaffer
01-11-2005 06:25:10
 Re: Billet Camshafts in reply to Carney worker, 01-10-2005 16:22:35
Email me with cost please. I build Oliver motors for pulllers and we may be able to get a bunch done up. Thanks Charlie
hobby77
01-10-2005 23:26:11
can you do one for a 77 with stock cam bearings if you can how money for a finished cam .
Carney
01-11-2005 09:47:30
 Re: Billet Camshafts in reply to hobby77, 01-10-2005 23:26:11
Finished will run real close to $750 with hardening and grinding, material, shipping and machine labor. No gear to drive oil pump
Smoke
01-13-2005 00:22:52
 Re: Billet Camshafts in reply to Carney, 01-11-2005 09:47:30
Two things:
(1) Why bother with the needle brgs? it is cheaper to make it with standard sleeve brgs and frictional coefficient is a wash.
(2) No Oil pump drive? Stock and stock appearing has to have an internal oil pump and on gas a distributor that is driven off the oil pump.
Carney
01-13-2005 07:09:03
 Re: Billet Camshafts in reply to Smoke, 01-13-2005 00:22:52
Try to turn it 5000 to 6000rpm and stay togather. A stock ignition is not accurate enough for the kind of performance needed. Crank trigger is. Stock oil pump, you might as well buy a pile of spare parts cause you'll need em. Cam breakin ollies need all the help they can get.
