weight bracket
Devin
01-07-2005 18:29:01
I am geting started in tractor pulling. I was wondering what was the best way to put the rear wheel weights on the back of a Farmall H or M. I see that people have the brackets that bolt to the hub and then thay have flat iron sticking out from the hub I was wondering if any one had the measurements to make those brackets if that is the way to go. Any help would be good to me. Thanks Devin in PA
Dave in MN
01-09-2005 17:15:14
 Re: weight bracket in reply to Devin, 01-07-2005 18:29:01
You can measure the inside of your round weights and make a rectangle bracket for them to slide on to. You will have to make them slightly smaller for the weights to slide on easier. I much prefer the suitcase weights over the 150 rounds. I have a set that I could sell you, but it will be cheaper for you to make your own.
savsmm
01-08-2005 09:39:23
I have seen these....do they built these brackets just so that it is easier to get the weight on and off? I have a MM U that I am going to pull and thought about doing the same thing.
Chris
