Rd 450 in a 460
RP673
01-04-2005 20:07:26
Anyone out there willing to give up some info on a clutch, flywheel combo for a Rd 450 in a 460? Been thinking and looking for some tried and proven ideas. Thanks.
Dirtslinger
01-04-2005 20:58:05
 Re: Rd 450 in a 460 in reply to RP673, 01-04-2005 20:07:26
I don't know much about putting one in a 460... we have put one in a 560, and it was relatively simple....you can retain the stock flywheel if you wish (with some machine work), but the crankshaft flange sticks out alot more on an RD450 than it does with a 221-301 engine...we built a steel flywheel/double-disc clutch set-up for our 560...as we couldn't get a single-disc clutch to hold...you will also have to make a front engine mount and re-drill the the rear engine plate off of the the stock engine to get it to bolt to the RD450....It will also be difficult to retain the front steering bolster if you wish to do so, the RD450 is considerably longer than the stock engine (I removed mine). We have our tractor for sale if you would like to buy one that is already done....
SMTA Puller
01-05-2005 11:18:52
 Re: Rd 450 in a 460 in reply to Dirtslinger, 01-04-2005 20:58:05
I'm looking for a 560. Email me with information on your' tractor. What exactly is an RD motor?
Dirtslinger
01-05-2005 16:18:31
 Re: Rd 450 in a 460 in reply to SMTA Puller, 01-05-2005 11:18:52
An RD motor is the truck engine....the one that most guys are using the WK-40's....The tractor is listed in the photo ads....ad number 89683...
David
01-06-2005 04:04:50
 Re: Rd 450 in a 460 in reply to Dirtslinger, 01-05-2005 16:18:31
What kind of rpm's is it set up for?
Dirtslinger
01-06-2005 15:36:50
 Re: Rd 450 in a 460 in reply to David , 01-06-2005 04:04:50
At the local pulls, we usually ran it anywhere from 3500-4000 rpms...We did pull it at the 30% over stock rpms a few times and it ran well there also....
