MH 44 GS
Kevin
12-31-2004 20:30:56
Is a MH 44 Gas Standard a good pulling tractor? I am just getting started and am on a tight budget. The tractor is in great shape with the motor freshly went through. Is this tractor good to have fun on at pulls without dumping tons of cash?
Ronnie
01-01-2005 07:22:46
 Re: MH 44 GS in reply to Kevin, 12-31-2004 20:30:56
I dont think a standard is a good model. Yes a 44 is a good puller but the row crop model is better. But if you really want to pull any tractor is better then none.
Kevin
01-01-2005 10:17:27
 Re: MH 44 GS in reply to Ronnie, 01-01-2005 07:22:46
Will it be better than trying to pull an H in the 4,500 lbs class? How much does the 44 standard weigh? It cant be that much more than the RC can it? From what i have looked at so far i should beable to send a stock farmall M back to the pits with no problem, shouldnt I? It has more motor and more power.
marlowe
01-01-2005 11:41:16
 Re: MH 44 GS in reply to Kevin, 01-01-2005 10:17:27
a 44std. is a heavey tractor because of the front axele and cast wheels also not a real good puller because of the 30 in. rear tires 38 work a lot better DON'T think you will send all Ms back to the pits they are good pulles and i'm a massey puller with a lot of work you can make your 44std. pull lighten it. get rid of any thing you don't need and i have seen some guys put 38 rears on a std. but it's a lot of work
slowsmoke
01-01-2005 11:51:23
 Re: MH 44 GS in reply to marlowe, 01-01-2005 11:41:16
You can change axle/axle houseings to go to 9 bolt hub/38" tires. I think a RC with the longer frame balances better. Good luck
Kevin
01-01-2005 15:09:24
 Re: MH 44 GS in reply to slowsmoke, 01-01-2005 11:51:23
What can be done to lighten it but not ruin the stock appearance? I would like to run the 5,000 and 5,500 lb classes. 4,500 lbs would be buitiful but i dont want to strip her to much. Why are 38 rears better than the 30's? Doesnt a smaller shorter tire deliver more torque than a taller tire?
Should i put a straight pipe on it or does it run better with the muffler, i have some guys say they need some back pressure yet others say the straight pipe will give me 3-5 more hp. How many volt does the stock coil put out? And what is the highest amount of volts i should get a coil for?
What about wheelie bars and a hitch? How do i build them? I would like to take this tractor to some "plow days" so i need it to be a good usable farm tractor too.
What can i do to get more throttle response and alittle more rpm?
Last but not least, am i getting way into it with this tractor? Should i leave this as a stock restored farm tractor and look for something cheap for the 4,500 lb class? Just looking to do div. 1, or 2, what ever they run by me. Im on a really tight budget so i cant play around much. Im only 15 so i have alot of time to get a pulling tractor yet. I do have an H but i went with the 12.4 tires on that only so i screwed myself there.
