wanted Massey Harris 55 diesel pistons or sleeves
Floyd
12-31-2004 13:02:34
HELP! Needed MH 55 diesel pistons. Where can I feed them?
CASEPOWER
12-31-2004 13:28:42
 Re: wanted Massey Harris 55 diesel pistons or slee in reply to Floyd, 12-31-2004 13:02:34
Start calling some of the military surplus dealers. Look for a set for a Cont. JD 403 instead of a JD 382. They will fit right in and give you 1/8" more bore. The Military used them in Davey Permavane air compressors and some other stationary equipment. They also has a bolt-on balance shaft setup. It was for high RPM engines.It used main studs instead of bolts so they could bolt the balancer to the bottom. It ran off the crank gear. The 403 used a roosamaster rotary pump instead of the Bosch pump. The engine will also bolt right in if you can find one.
