question for mo power
jerry l
12-30-2004 19:06:38
just read a your reply to the beginner puller on a budget you talked about low compression 283 making in to a high compression 403 i've got a uts with a 283 all tore apart as we speak how do you do this conversion thanks jerry
Rich B
12-31-2004 13:06:56
 Re: question for mo power in reply to jerry l, 12-30-2004 19:06:38
Get doug hendersons number from mopower,he does great work,nice people to deal with.We have a GVI on LP his dad built,bad to the bone puller.Rich B
Sam Gingell
12-31-2004 10:35:26
There is video produced by J & D Productions that takes you thru a rebuild step by step. J & D Productions,Inc. P.O. Box 38 Metamora, Mi. 48455
ejr
12-31-2004 09:49:06
If want imformation on how to G a U call 417-498- 6496 Welters equipment Verona Mo.They can tell you how to this and the price for the parts.Or build up what you have .I have 4mm U with M5 blocks & manifold high comp.4210 heads.UB with 283 with 4206 heads popup pistons m5 manifolds.UB with M5 blocks popup piston 4210 heads.GVI with 605 well motor.
Dieselbear
12-31-2004 03:42:40
Offset grind G crank, 4.81 pistons, and 4232 heads
