least expensive tractor to modifiy/ beginner to p
tugboat tim
12-29-2004 12:48:21
I always wanted to try tractor pullin it sure looks like fun. but wife wont provide mutch funding I own a ac wd ford 8n jd-b and ih 460 all are complete stock thanks for any posts in advance tug boat tim plowin the waters on the east coast.
ALLIS MAN
12-31-2004 21:29:21
 Re: least expensive tractor to modifiy/ beginner in reply to tugboat tim, 12-29-2004 12:48:21
I HAVE BEEN PULLING A WD FOR THE PAST 4 YEARS AND HAD GOOD LUCK. ONLY HAVE $2800 INVESTED. THAT INCLUDES A NEW MOTOR WITH WD45 CRANK. ALSO PUT A SET OF 38" WHEELS ON BACK. IT PULLS GOOD FROM 3350# ALL THE WAY TO 4500# IN THE LOCAL 4MPH CLASS.
Mo Hay Baler
12-30-2004 23:00:41
The 460 is the most stock horsepower you own.I would weight it down just a little to the 6500 class on the rear wheels and ride it straight down the track.You will be pleased,and not spend much either.
Jeff Oliver
12-30-2004 19:31:27
I would take the AC and put the wheelie bars and weight brackets on it and go have a ball. if you have enough power and the rules allow I would recoomend a 38 inch wheel on them but that usually requires some engine mods. Get your hitch up to the specs the rules allow, here it is 18 inches from center of axle and either 18 or 20 inches from the ground depending on whose sled we are pulling. Then work on balancing the tractor and reading the track. hehe now don' get too serious about it at first or you will ruin all the fun!!!
Hook and pull and have a good time. Ya probably won' win them all but as long as ya have a good time and enjoy the companionship it''s all worth it !
Ken B
12-31-2004 04:18:05
 Re: least expensive tractor to modifiy/ beginner in reply to Jeff Oliver, 12-30-2004 19:31:27
All of that AC stuff comeing from the Oliver man
Jak
01-01-2005 16:32:00
 Re: least expensive tractor to modifiy/ beginner in reply to Ken B, 12-31-2004 04:18:05
Get on him Ken he needs it.
Jeff Oliver
12-31-2004 07:13:35
heheh yea I know I should be publicly flogged but I was just working with what he has on hand:) Besides there is a WD around here that is pretty danged tough from up around Crutchfield.. hahahhaa!
How are ya'll doing? Finally dig out from the snow and ice I guess huh?
CLIFF
12-30-2004 18:26:29
GUYS the man said he is on a budget, ALL your tractors will pull ok in there own classes, I would try the ones that you think will do the best in your aera and put some weight brackets on them work with tire pressure and balance and have FUN, Later as budget allows modify to better your pulling. cliff
Mopower
12-30-2004 05:05:11
The absolute cheapest tractor to pull would be a Minneapolis Moline U or UB. Parts are all over and bigger and better late engine parts bolt right on. Just a few hundred dollars and a low compression 283 cu in U is a high compression 403 cu in engine good for any speed limit classes. Interchangeability is the key word. These things are like leggos and easy to work on.
Ritchie Wilson
01-02-2005 18:54:56
 asking? Mopower in reply to Mopower, 12-30-2004 05:05:11
Mopower, how about telling me what parts i can use from ohter molines on my ub for more power.I pull in southeast New Mexico email me [email protected] Thanks
topsarg
12-30-2004 04:08:51
Tim:
Don't forget your Ford 8N, they are a very competitive tractor stock, especially if you have 2500 thru 2750 weight classes. No engine modifications necessary. Call me if you would like 918-434-6754, or email.
buickanddeere
12-31-2004 01:31:22
 Re: least expensive tractor to modifiy/ beginner in reply to topsarg, 12-30-2004 04:08:51
Those little Ford 901's are little powerhouses as well or can easily be made into one. A local puller has one in the 4000 & 4500lb classes and the flag man has to jog to keep up with him. There must be some four cylinder car engine that will bolt in there. I'm certain he's running 90+HP. My 65HP doesn't even come close in speed.
buickanddeere
12-29-2004 20:13:40
Each to thier own but I would suggest getting good in a stock class before souping $$$ tractors. If you take care of the three most important factors in winning. Which are traction,traction and traction. Then you can go onto more wheel speed in higher classes.
JDH
12-30-2004 04:06:20
 Re: least expensive tractor to modifiy/ beginner in reply to buickanddeere, 12-29-2004 20:13:40
Spend your money on a good trailer and take all three stock and see which one you like best.
jd b puller
12-29-2004 19:35:17
I don't know much about the other tractors, but assuming you are going to pull in a (3.5mph)speed limit class, you can stick a power block in a later model B (1947-1952) and play in creeper gear for less than $1500. You may not win, but you should be competitive. Keep it in 3500 and 4000 though...
AC
12-29-2004 18:06:32
That 460 is a good tractor, especially if you put a combine engine in one...but I think an allis WC/WD is the cheapest HP per $ you can get, with the 460 a close second....
ollie88
12-29-2004 17:36:56
First buy an Oliver.Once you go the right green you will never go back.
actually anything is fun to pull - guess the big question is how much you want to spend!!
don44
12-30-2004 16:01:35
 Re: least expensive tractor to modifiy/ beginner in reply to ollie88, 12-29-2004 17:36:56
ollie you have red looking tractor that pulls better good don't you ????
wolfmantractor
12-29-2004 16:38:05
First choice- the 460. 2nd choice-the 460 next the 460. I run a county fair pull; if a 460 is entered, people wonder who might come in second.
Solid Junk
12-29-2004 15:02:25
I would say your best bet is probably the 460 if your local rules will allow a tractor of that year to pull. The 6 cyl will allow for plenty of upgrades down the road, or you can find a combine motor that will bolt in.
just my opinion
Joe
supermpuller
12-29-2004 14:51:56
Hop up the WD or put in a combine motor in the 460.
Agent Orange
12-29-2004 16:38:59
 Re: least expensive tractor to modifiy/ beginner in reply to supermpuller, 12-29-2004 14:51:56
I'd go with the WD for a beginner, I've been pulling mine for 4 years now and with a little upgrade each year you can do very well.
mhf
12-29-2004 20:41:07
 Re: least expensive tractor to modifiy/ beginner in reply to Agent Orange, 12-29-2004 16:38:59
Find a c or d series case find a A5505 head for it have it shaved 100 thousanths and you will have a godd 3 or 3.5 speed limited tractor for easily 1500. And they are tuff to beat if balanced good. you can pull 3500-5500 depending on which tractor you have.
