Roller rockers
Shaggy
12-27-2004 14:25:59
Would a set of rollers rockers help you low end power or hurt it? if the cam is stock. From what I have been told the stock is a 1.33 and the roller set up is around a 1.62.
Thanks
G/MAN
12-28-2004 13:38:49
 Re: Roller rockers in reply to Shaggy, 12-27-2004 14:25:59
As Dennis said, the increased duration will tend to move the powerband up some in the RPM range and may rob some low-end lugging ability, but the increased power up top (due also to the increased duration and more valve lift) should offset it with better overall performance. And of course if the rockers have roller tips it will reduce the rocker arm's "scrubbing" of the valve tip and be easier on the guides, in addition to freeing up a little power there due to lower friction.
Dennis Andres
12-27-2004 15:45:45
I bought a set for my 60 JD.It increased horsepower but I lost some lower end torque
