450 parts
W.B
12-26-2004 20:10:27
Anybody know a good place to get pulling parts for a 450? I"m gonna have my 450 stroked and i"d like to know where to get pistons. Probably have it stroked an inch. Id like to buy a set of pistons i can bolt in and use mu stock rods and cam. Is it possible?
ChadS
12-27-2004 04:39:58
 Re: 450 parts in reply to W.B, 12-26-2004 20:10:27
I have stock bore high compression pistons for up to 6 inch stroke, stock rods. Im building a 450 later this month,, it will be a 5-3/4 stroker with 4-1/8 bore, at 240 psi of compression, shooting for a shade between 90-95hp. It will be a high compression engine, so minimum of 100 octane will be required. Have heard of a JD piston that works at 6-6.25 stroke, at 4.25 bore,, cant remember what model of JD it came from,, A fellow by the handle of Ohio M Puller told me bout that set up, Said it was a very good combo! Hope this helps a bit,, ChadS
W.B
12-27-2004 18:52:47
 Re: 450 parts in reply to ChadS, 12-27-2004 04:39:58
Could you email me with the cost of the kit you have and what all it includes? I may be interrested in 2 kits and possibly one for 350 engine. Thanks
FB
12-28-2004 18:30:22
 Re: 450 parts in reply to W.B, 12-27-2004 18:52:47
i think it s the 4020 LP piston
