Weight of Farmall M
Jim
01-22-2002 10:40:51
What does a Farmall M weigh without weights, without fluid in tires, with hydraulics, with PTO and with or without belt pulley assembly? Fenders and belt pulley assembly I can easily figure. As you probably can tell I am trying to get my M ready for a specific weight class. Not sure with 14.9 tires if I am better off trying for the 5000 or 5500# weight class. I do not think that I want to go higher without really reworking the engine. Any help and opinions are welcome. Thanks! Jim
h
01-23-2002 17:25:17
 Re: Weight of Farmall M in reply to Jim, 01-22-2002 10:40:51
I seen one Pull 3500 lb At Murray?
Don
01-22-2002 20:40:04
I have a M I pull, No calcuim, no weights, just 5ft angle iron for weights,. belt pulley drive, no pulley, hydraulics on it, 13.6 tires,. with me on it weighs 5100. I'm around 160. I pull 5500 and 6500 class strickly stock. I pull 7500 too but not enough power. I got a super M too it does good in 7500. Hope this helps. Don
phil
01-22-2002 20:05:59
my farmall m completely stripped with tin wheels will make 5000. im guessing yours would weigh 5300-5500
Mike
01-22-2002 14:36:20
you will have to strip to make 5000# class, lot of M's pull one front wheel to make the class.Probaly deciding factor will be how much ballast is in the seat. Good luck
Phil
01-25-2002 10:15:50
 Re: Re: Weight of Farmall M in reply to Mike, 01-22-2002 14:36:20
My stock M weighs 5050# with me on it at 160#. It has hydraulics, no belt pulley, swinging drawbar, and both fenders. It has 13.6-38 tires.
