New to pulling need to know the basics
Mattme
12-22-2004 09:17:40
I"ve started to tinker on an old ford super major, and was interested in pulling at the local shows. What"s some good basic tips to improve ones distance? I"ve been considering things such as tire pressure, draw bar height, etc... If a person was to add weight, is their some sort of rules as to where along the tractor it can be placed? Seems like this machine would spin rather than start pulling the front off the ground.
buickanddeere
12-23-2004 05:05:04
 Re: New to pulling need to know the basics in reply to Mattme, 12-22-2004 09:17:40
Only three things to remember. Traction, traction and traction. Without traction a 50HP two cylinder will beat a 2500HP super stock. Max legal weight, max legal drawbar height and balance the for/aft weight so the front wheels are 1" off the ground as she spins out.
thejdman01
12-23-2004 08:49:49
 Re: New to pulling need to know the basics in reply to buickanddeere, 12-23-2004 05:05:04
the best advice i ever got was attend and keep your eyes open and your mouth shut and youll learn alot. maybe if you find some pulls locally youll find sooneone whos pulling a tractor that you got and see where they put the weight etc and just watch learn and tinker the more you tinker with ONE ONE ONE variable at a time the mosre you learn. if you switch 10 things at once you wont know whats working for you and whats working against you.
Goldie
12-22-2004 22:15:28
Go to as many pulls as you can and try as many things as you can. The fist pull I went to I came in last 6 or 7 pulls later my brther took first with it. It was just a matter of knowing what gear to use and were to put the wieght.
bigman
12-22-2004 19:05:10
never know till you try
