Sleeve Material
mhf
12-20-2004 19:16:51
If you bore a block out what can you use to make sleeves out of.
Earl S.
12-21-2004 10:07:29
 Re: Sleeve Material in reply to mhf, 12-20-2004 19:16:51
There is sleeve material up to 12in bore x24 in. What size do you need.Email if you need help.Earl
torquenut
12-21-2004 10:41:16
 Re: Sleeve Material in reply to Earl S., 12-21-2004 10:07:29
Another question since we are talkin' sleeves... how about o-rings, where can one get o-rings for sleeves?
Earl S.
12-21-2004 12:12:17
 Re: Sleeve Material in reply to torquenut, 12-21-2004 10:41:16
Just type in ("O" rings Parker) hit search.Earl
mhf
12-21-2004 15:22:08
 Re: Sleeve Material in reply to Earl S., 12-21-2004 12:12:17
EARL It sounds like you've been down this route you couldn't possibly tell me any L case combination's could you.
Earl S.
12-21-2004 17:10:39
 Re: Sleeve Material in reply to mhf, 12-21-2004 15:22:08
Where do you live?? Do you want to run water in the block?? Are you stroking??If you use the low comp head its more of a open chamber(bigger valves not shrouded) then you can bring the comp back with the piston with step head dome.Email if you want to communicate faster.Earl In Illinois
