jd a opinion
jons
12-19-2004 19:16:23
just wanted to know what you guys think the best stoked crankshaft (bore stroke) combination is for a jd a?
JLO
12-22-2004 05:04:40
 Re: jd a opinion in reply to jons, 12-19-2004 19:16:23
THE A I HAVE FOR SALE HAS EXC. PAINT ALL THE WT. BRACKETS FOR UP TO THE 7000# CLASS, IT IS SETTING ON CUT 151"S I AM ASKING 6500.00
living to pull
12-20-2004 14:29:14
JDA How much are asking for your A and what year and what kind of paint what size tires
dej(JED)
12-20-2004 10:22:34
You can buy a good puller for a lot less than you could ever build one.
JDA
12-20-2004 10:20:09
I HAVE AN A WITH 5.75 BORE AND 8.75 STROKE READY TO GO FOR SALE
cube king
12-20-2004 06:38:28
Go for the gusto!! Find a powerblock, sleeve it to 6.25, add 9.25 stroke, good for 570 cubes. A fair amount of work required but anything you do as far as stroking will be and as long as you're doing it, spend a little more time on it. Have one at 662 cubes and don't regret it.
Good qustion
12-19-2004 19:29:53
Make sure you preface that with... how long you want it to last? What RPM's? How much work do you want to do?
How much money do you have?
jons
12-19-2004 19:41:05
 Re: jd a opinion in reply to Good qustion, 12-19-2004 19:29:53
want something that will last, but still have power. labor is not a issue. i want to use my stock block without having to buy a power block. maybe like 5.75 bore and 8.50 stroke? or maybe 5.875 x 9 any ideas?
Super Lurker
12-19-2004 21:47:21
 Re: jd a opinion in reply to jons, 12-19-2004 19:41:05
I have a friend that has an unstyled A with a 5.75 X 9 motor, that has been pulled for years without any problems. It runs good and pulls good---may not always win, but it's always in the hunt. Good tractor with lots of compression.
JDGnut
12-20-2004 08:43:39
 Re: jd a opinion in reply to Super Lurker, 12-19-2004 21:47:21
The 9x5.75 has been around for a while.. (Got one on the stand now..) and most have proven to be a durable set-up.. but there is bigger stuff out there... If you are going with the stock block.. I'd go 9.25.. maybe 9.375.. by 5.75... Good Luck
JDGnut
