ChadS
12-20-2004 18:42:30
Re: less weight=more or less power? in reply to buickanddeere, 12-20-2004 15:40:23
It would help alot in throttle response time,, that I agree 100%. I think of a 2 cyl JD and how heavy the pistons, the rods, and the crank are, and how much torque they make in low rpms. Ive never been one to love to rev up an antique, unless it was balanced properly to run the higher rpms. Im one for 540 and below rpms on dynos,, In tractor pulling, you need gobs of torque, and look how heavy those cranks rods, and flywheels are in these engines! Built to lug the dickens out of them, all day long. Pulling engines are not much different, you hit a tough spot in a field, or on the track,, the tractor is gonna lug down, maybe even stall it. What could help keep the engine rotating under these circumstances? heavier, lighter flywheels? lite, or heavy rods, cast, or lite aluminum pistons,, Compression??? Always belived,, that heavy internal parts, and high compression compliment each other, to build torque,, hp comes natually,, on lite engines,, you make hp,, and can rev them higher, but ask any one who runs an oliver that has lite rods in them,, big hp when they are 2500+rpms,, drop em in a hard lug, below 2000, and they will fall on thier nose, or they will stopthem before they do any damage. (Not picking on Olivers guys!!!!! Please dont read me wrong! but, Ive seen one too many 15 mph olivers die at the end!) Also seen em shoot rods out the pans when they did put a lug on it.. thats a high rpm lite weight engines charateristics, racing,, not pulling,, Now the Olivers have gotten better in div 2 and 3, they dont seem to be reving them up so high inthese classes, and can lug them, but, betcha they are not very lite inside the engines,, I can stick my foot out, and say that each part weight, all the same, would help in not shaking so bad at higher rpms,, it relives stress from the crank a bit,, in an engine that should constanlty change rpms on the track, guess I wouldnt know which I would want, would it make that much difference when the lug is put on it? ChadS
