Pistons and sleeves from 5 -5 1/2
King
12-19-2004 18:46:04
Does anyone know of a piston and sleeve combination that is in the range of 5 inches thru 5 1/2? I would like the largest i can find in that range. Any help would be appreciated. thanks King
isdetxmn
12-20-2004 06:09:29
 Re: Pistons and sleeves from 5 -5 1/2 in reply to King, 12-19-2004 18:46:04
G.M.C. v6 5.25"
King
12-20-2004 16:43:31
 Re: Pistons and sleeves from 5 -5 1/2 in reply to isdetxmn, 12-20-2004 06:09:29
Thanks for the help its kind of hard to get anything out of anyone on this board. That is unless you have a green or red tractor then the help flows freely. thanks agin King
nc jd guy
12-19-2004 18:54:05
What are you putting it in?
King
12-20-2004 03:40:59
 Re: Pistons and sleeves from 5 -5 1/2 in reply to nc jd guy, 12-19-2004 18:54:05
Im wanting to put it in a L Case.
jd b puller
12-20-2004 18:24:12
 Re: Pistons and sleeves from 5 -5 1/2 in reply to King, 12-20-2004 03:40:59
There are 5-1/8 Lycoming airplane pistons out there and 5.5 Cessna pistons which would work well. I would try to avoid diesel pistons. They are usually quite a bit heavier than gas ones.
