MH 44GS
Kevin
12-18-2004 20:13:23
What kind of cheap bolt on stuff can i do with my MH 44 GS to build some cheap torque/HP. I dont want to do anything to much as i know most classes are called farm stock and i dont know what is allowed, but i know everyone has alittle something done to their tractors. Now i know when i was going to set up the Farmall H for pulling there was stuff like swapping out the carb/manifold, cam, and cheaper stuff like that that would give more HP. Is there anything like that i can do with a MH 44 gs? Just use your basic judgment and rules from your area to help me keep this tractor fair.
Farmall pULLER
12-21-2004 10:01:05
 Re: MH 44GS in reply to Kevin, 12-18-2004 20:13:23
You can add a hot coil, wires,and plugs. Then you need to move your hitch forward toward the rearend. Put 94 octan gass in it. you can also put a stiffer govenor spring in it to. And last adjust the carb so when you open the throtle up it should smoke just a little. This should help you out.
good luck pulling, Miles
FARMALL H PULLER
12-21-2004 10:04:41
 Re: MH 44GS in reply to Farmall pULLER, 12-21-2004 10:01:05
Most rules are you can move the hitch to 18 in. from the center of the rear axle.
Miles
Masseypuller
12-21-2004 05:30:58
The only cheap horsepower that can be bolted on to a (stock) 44 is a new carburetor. A Marvel Schebler from a U or G Moline with the throttle shaft reconfigured to work correctly for a 44 will bolt on approximately 5HP to a stock engine.
Kevin Tarbox
12-21-2004 18:54:07
 Re: MH 44GS in reply to Masseypuller, 12-21-2004 05:30:58
Are you aloud to change the carburator for most pulls? Even farm stock? I think following farm stock rules is the safest way to go.
Kansas44puller
12-19-2004 11:05:17
If your 44 motor is in good shape it should be able to pull "farm field" (div 2) in low gear. I pull mine in 4500 and 5000 lb classes with a stock motor that waa overhauled 35 years ago. Finding the right TIRES are the hardest thing along with building a good pulling hitch. Hope this helps and good luck
Kevin
12-19-2004 11:17:34
 Re: MH 44GS in reply to Kansas44puller, 12-19-2004 11:05:17
The motor is freshly overhauled and it has 14.9 firestone tires on it.
