What rim for 16.9 tires?
Migraine
12-16-2004 20:19:11
I'm getting ready to mount a set of 16.9 /38 tires for pulling. They are Armstrong 6 ply bias with about 25% tread and are pretty sharp on the edges. Should I use 14 or 16 inch rims on them. I've been using 14 inch but I wonder if the tires would lay out flatter with 16 inch and actually pull better? Please let me know what is working for you! Migraine
The Rodent
12-17-2004 16:19:32
 Re: What rim for 16.9 tires? in reply to Migraine, 12-16-2004 20:19:11
I would probably recomend a 16" rim, the wider the tire the more bar is bitting the track.
Mike Aylward
12-17-2004 08:43:12
Migraine, the 16" rim is just where you want to be. The manufacturers recommendation for a 16.9 tire is 15" so the 14 would be a tad narrow, although there are several running that way. The 16" rim will allow a nice, straight sidewall which is what you want for a pulling tire. Mike
JPatton
12-17-2004 05:33:59
Migraine - Like Tire Guy said. Wider is usually better. But, you need to check the rules where you pull. A lot of clubs have rules about rim width for tires that are uncut. Usually they cannot be mounted on rims wider that what is recommended on the tires sidewall, Good luck. J
tire guy
12-16-2004 20:55:27
16in is better
"wider is better"
