need 5 3/4 pistons
living to pull
12-13-2004 18:42:28
I am looking for as set of aluminum pistons that are 5 3/4 in for a unstlyed A I know all john deere goes to is .125 over I need .250 to make it 5 3/4. I heard there is a cat dozer that has them and if anyone makes pistons let me know very serious the tractor is standard 5 1/2 thanks
jd puller
12-14-2004 14:31:54
 Re: need 5 3/4 pistons in reply to living to pull, 12-13-2004 18:42:28
get a set of d-8 7U pistons they are 5 3/4...you will need to make a set of bushing for the wrist pins but thats easy...e-mail me if you are intersested in getting a set made.
J.P. Dunn
12-13-2004 19:58:38
$350 for pair of 5 3/4 aircraft pistons with rings, pin and the original connecting rod (to be welded to the journal end of your current rod) (works well with JD 329 rod when stroking or off-set grinding the crank).
living to pull
12-14-2004 14:10:22
 Re: need 5 3/4 pistons in reply to J.P. Dunn, 12-13-2004 19:58:38
Will they work on a regular non stroked A. all I am doing is putting a late model crank in a ustlyed A. what is the length If they will I will buy them. the reason I am not going all out is that I just bought the indiana eagle modifeid tractor and I just want to make a descent 4 mph tractor
Down the chimney!
12-14-2004 15:29:11
 Re: need 5 3/4 pistons in reply to living to pull, 12-14-2004 14:10:22
Question, what happened to the eagle a@ Tunica, I just seen it smoking from under the hood real bad. How old did you say you was? I bet ole sait nick won't come to your house for a couple of years after bringging you that thing?
living to pull
12-14-2004 16:49:33
 Re: need 5 3/4 pistons in reply to Down the chimney!, 12-14-2004 15:29:11
I am 19 I have already told everyone before that I bought the tractor with my own money and no help from anyone else I think that is sorta disrepectful on your behalf. And the tractor was smoking because that was the first time it had been pulled since august. it has some condensation in it all of them will do this when they sit for a peroid of time. I am not trying to be rude but alot of people think that my partens have bought this tractor for me but they are 100% wrong. and the reason is because I am younger than most pullers. I am still competion and I feel that I should be treated with some respect
family tradition
12-14-2004 15:25:55
I did find the pistons today. They are 5 3/4 and need rings. We bought these pistons about 15 years ago to put in a styled A with a 7 1/4 inch stroke and sold the tractor before we installed them. I have not found the bushings yet, but I think they are around here somewhere. Like I said, they have been sitting around here for about 15 years! LOL
family tradition
12-13-2004 19:02:55
I think I may have a set from a Cat, not sure, I will check tomorrow and post back, if so, I think I have the wrist pin bushings also, just have to check and see
