First time puller
Engineer20
12-13-2004 09:07:57
Hi all,
This summer I picked up an all original Case LA propane to restore. I'm not building it to pull with, just an original restore. It runs great. I figure that before I start the restore I will have a chance to pull it in the county fair and a few other antique pulls. I have never pulled before. My biggest question is what gear do I pull in? Do I leave it in 1st or put in 4th which is road gear?
What other things should I be aware of?
Thanks for any help,
Mike
Andy2
12-13-2004 19:44:06
 Re: First time puller in reply to Engineer20, 12-13-2004 09:07:57
I would say low gear depending on wieght and track. LP's are great pulling tractors even in stock form. We pull several LP MM's and have a lot of fun.
Agent Orange
12-13-2004 15:32:38
Just have fun in low gear! You can but a trophy for less than a hook fee! Hope you have as much fun first time out as I did!
dctom
12-13-2004 15:05:47
best way to learn is go and hook and every time they drop the hook learn something, no one can tell you how to run your tractor, one very inportant thing, when you get beat dont go look at his tractor look at yours and try to figure out what to do to beat im tom
Engineer20
12-13-2004 15:14:58
 Re: First time puller in reply to dctom, 12-13-2004 15:05:47
DCTOM,
Not to worry. The last thing I'm trying to do is compete, just have a little fun. Just trying not to look like to much of a dummy out there. My goal is to restore her to her original good looks!
skylar
12-13-2004 10:33:28
On a stock or even a little tweeked, leave her in first gear.That sled looks like it pulls easy, but it pulls hard in reality.Good luck and have fun.
maco
12-13-2004 12:13:10
 Re: First time puller in reply to skylar, 12-13-2004 10:33:28
You can put it in 4th gear to get to the pull, once hooked to the sled you will need low gear!!!
