Stroked cranks.
David H
12-13-2004 07:10:07
Who does good work in the Southeast? Something that will hold together? thanks
Marty in Mi.
12-15-2004 13:17:28
 Re: Stroked cranks. in reply to David H, 12-13-2004 07:10:07
If you want the best, call Jim Benjamin in Webberville Mi. He builds all of Bakers cranks. His cranks will more than likely out live you. He may be a little more expensive than a few of the others, but how can you put a price on getting your crank stroked by the best. Marty
ollie88
12-13-2004 19:00:50
I use Southern Illinois Crankshaft - Red Bud Ill - Mike does what you want at a very reasonable cost. I have never had a problem from anything he has done!!!
puller
12-13-2004 14:45:16
genes mechine
maco
12-13-2004 12:10:04
Merfeld cranks. Dubuque, Iowa. He does excellent job. Just a crank or turn key motor.
David H
12-13-2004 15:39:26
 Re: Stroked cranks. in reply to maco, 12-13-2004 12:10:04
Do you know the phone numbers for either? Where is Genes? Thanks
puller
12-14-2004 16:30:47
 Re: Stroked cranks. in reply to David H, 12-13-2004 15:39:26
i lost genes number if you go one pulloff.com and ask in the feedback page they will tell you. that is a good place to get info on stroked cranks. i have had one from south ill. and the welds came loose and junked out the crank and oilpump. gene does a good job and is easy on you poketbook
stroked crank
12-13-2004 18:03:38
I think Merfeld's number is (563) 585-5000. He is in Dubuque. I just checked and it is going to cost me less than $50 to mail my crank by FedEX. They are about 1/2 of UPS. If you ask around, you will hear good and bad about every machine shop out there. I have heard a lot more good than bad about Merfeld. He also seems to know quite a bit about Deeres.
big crank
12-14-2004 06:50:16
 Re: Stroked cranks. in reply to stroked crank, 12-13-2004 18:03:38
merfeld is in peosta iowa 563 582 8710
