chads i need help
dock
12-10-2004 17:07:05
put m&w crank in a m with 4 1/8 dome piston. problem is that it sticks out of the block 1/4 of a inch.
trulyred
12-10-2004 19:18:05
 Re: chads i need help in reply to dock, 12-10-2004 17:07:05
Done this very same thing several years ago, cut the pistons off, tractor started at an idle just fine, when I gave it some throttle four holes were made right square in the center of each piston. You need the correct pistons for the crank, I think you can get them from Herschel/Adams, they have a website.
ChadS
12-10-2004 17:18:10
Email me, I left it open, may have to machine the tops in a few places to fit them in. what kind of pistons did you use? ChadS
Trkr
12-10-2004 17:54:58
 Re: chads i need help in reply to ChadS, 12-10-2004 17:18:10
Arent you supposed to use the correct M W piston esp for the crank?Believe it has the wristpin moved up 1/4 of an inch.
ChadS
12-10-2004 19:35:50
 Re: chads i need help in reply to Trkr, 12-10-2004 17:54:58
Yes, they relocated the compression height for the M&W stroker. I am making replicas of them, but with a taller dome. 4-1/8 bore, depends on what rod you use. M, or 450 rods. Relocating the wrist pin height to help set the compression height. ChadS
dock
12-10-2004 19:41:22
 Re: chads i need help in reply to ChadS, 12-10-2004 19:35:50
how can i get a set of pistons? rods came out of a super M. Just trying to use parts laying around the shop.
ChadS
12-10-2004 19:43:49
 Re: chads i need help in reply to dock, 12-10-2004 19:41:22
574-893-7437 in the morning. are they the big pin, or the small pin rods? ChadS
dock
12-10-2004 19:48:21
 Re: chads i need help in reply to ChadS, 12-10-2004 19:43:49
they are the big pins. thanks will call you in the morning. thanks
dock
12-10-2004 19:13:23
I'm sure you are right, but don't have the pistons. where could i find them or what can i do
