F30 farmall hubs on a Moline
RED gone Yellow
12-08-2004 19:37:00
Anybody had any expierence putting hubs from a F30 on a G moline? I have heard that the F 30 hubs would match the splines on the Moline axle. Any info appreciated.
ejr
12-08-2004 21:02:07
 Re: F30 farmall hubs on a Moline in reply to RED gone Yellow, 12-08-2004 19:37:00
I think they are if their not tappered .Your's probably have the nut on the end of the axle instead off a snap rings.
ejr
12-08-2004 20:29:22
I have that in mind too for my GVI.They fit the splines but I just have the snap rings to hold them on will have to use a bushing to take up the slack so they won't slide back and forth on the axle.I'm having my son a machinist make a nine bolt hole pattern in them should work great.Saves allot of weight.
T
12-09-2004 06:31:32
 Re: F30 farmall hubs on a Moline in reply to ejr, 12-08-2004 20:29:22
just tap the hubs thaat are on the GVI litty heavy but will not breake
RED gone Yellow
12-08-2004 20:47:35
So they do actually fit ? Is the axle on a GVI and a GB the same size. Thanks for the info.
ChadS
12-09-2004 04:22:00
 Re: F30 farmall hubs on a Moline in reply to RED gone Yellow, 12-08-2004 20:47:35
Why not make 9 bolt welded plates,, that have the G6 axle spline alerady cut in them? Chad
