need more hp
m pulluer
12-08-2004 13:39:11
I have an M that I pull..I know a guy that also has an M, but he can pull 6500lb class in 4th gear while I'm in 1st..I need help to turn heads..money doesn't really matter...I'm sick of getting smoked....thanks.
Andy2
12-08-2004 20:01:54
 Re: need more hp in reply to m pulluer, 12-08-2004 13:39:11
Sounds like you need to find pulls with better rules. If you go to pulls with speed limets (3-4 mph) it levels the playing field a lot.
deep pocket
12-08-2004 17:19:09
call Denny's for big engine kit
Minnieman
12-08-2004 17:08:26
Maybe ya should of purchased a Moline GVI. ooopppss
colekicker
12-08-2004 15:37:10
I would guess if he is able to run 4th and you are in 1st and that's all you can do, he has a little more under the hood than you do. Probably a stroker kit of some sort. Also, what size tires ya run can make a difference. Track conditions can also change things too.
LITTLE M
12-08-2004 15:19:37
If you are looking for more power in your M, You need to get in touch with FARMALL. One of the best in the biz..
