Super 77 weight
mshadow77
12-07-2004 18:42:31
I HAVE HEARD OF 77'S PULLING IN THE 4000 TO 4500 POUND CLASSES. MINE WEIGHS ABOUT 5300 WITH FOUR WEIGHTS TOTAL ON THE REAR TIRES, NO LIQUID. iF I TAKE THE WEIGHTS OFF TO GET INTO A LIGHTER CLASS, WON'T THE TIRES JUST SPIN INSTEAD OF DIGGING IN BECAUSE OF THE LACK OF WEIGHT ON THE REAR. I HAVE SEEN 77'S PULL WITHOUT WEIGHTS AT ALL, BUT WAS NOT SURE OF ANY LIQUIDS IN THE TIRES. CAN SOMEONE ENLIGHTEN ME ABOUT THIS. THANKS!
Mike
770
12-08-2004 13:59:23
 Re: Super 77 weight in reply to mshadow77, 12-07-2004 18:42:31
My 770 with flat tops and wide front will get into the 4500 lb class. No fluid and no weights of course....Yours Should weigh about 50-80 lbs less due to smaller fenders.....I also have pressed steel all the way around....
anothertractor
12-08-2004 04:52:16
I am not sure how much difference there is between a 77 and a Super 77 but mine weighs 3700 lbs with no driver, weight brackets, 14 " pressed steel and 14.9s with no fluid and no weights. It also still has the hydraulics, pto, and belt pulley. I am sure that I could get it into the 3500 lb class but it would not do very well. Now, I weight it to 4500 and 5000. I have to put nearly all of the weight on the back to get the traction I need.
Rich B
12-09-2004 10:44:56
 Re: Super 77 weight in reply to anothertractor, 12-08-2004 04:52:16
I run my 77 in 3500 and up,never been beat in 3500-4000 lb open classes most always in top 3 in pace classes 3-5 mph.77 is one of the best "lightweight tractors" out there,but I'm not picky on color they ALL can be made to run.
Think spring, Rich B
stroker88
12-07-2004 19:19:58
it"s not unusual to see 77 in 4000 lb class. had a 77 that was in 3500 lb class. have 88 that makes 4000 lb class. even get 66 down to 2750 lb.
