How to get more HP out of my G jd
Mississippi Far
12-07-2004 18:28:43
Id like to get some HP out of my tractor without doing heavy moter work Any ideas
Dougie
12-09-2004 13:49:18
 Re: How to get more HP out of my G jd in reply to Mississippi Farmer, 12-07-2004 18:28:43
What's done to it? You can get a 3" exhaust, jerry's manifold, take the stock breather off. I need to know what's done to it b/c some of the "cheap" horsepower could hurt you.
Dougie
Mississippi Farmer
12-09-2004 17:08:50
 Re: How to get more HP out of my G jd in reply to Dougie, 12-09-2004 13:49:18
Dougie
The tractor has nothin more than what came in the box
Dougie
12-09-2004 17:22:43
 Re: How to get more HP out of my G jd in reply to Mississippi Farmer, 12-09-2004 17:08:50
You might want to bore it out .125 and get some HC pistons if you can afford. I heard stroking is the best thing you can do, but it"s pretty exspensive and I had to do w/o. Have some who knows what their doing and have them tinker w/ the carb. The timing is probably set up for the most economical, instead of horsepower. It"s the way it came from the factory. Another thing is to check to make sure you have a DLTX 51 (Big Nut) carb. If you have the magneto, get a distributor and a good coil. Get your head polished, ported and have them shave the head down to the eyebrows. I can"t remember how much shaving that is though. If you do this, the jerry"s manifold and the 3in exhaust from Crum Equipment will help you. Buy the high octane fuel, this helped me big w/ the performance. This is pretty much my set up and I won the last 3 out of 5 pulls w/ and one 2nd in the antique class. If I can remember anything else, I"ll tell you.
Dougie
jdtruble
12-09-2004 06:09:28
How about trying the slow release NOS or rigging up a blower in it?
massey harris 22/44
12-08-2004 15:05:23
PHIL, IT'S LIKE I TOLD YOU SELL THE G FOR A TROT LINE WEIGHT. AND BUY A MASSEY!!!!! BUT SERIOUSLY TALK TO MR. WALTON AT THE TIRE CUTTING SHOP, AND ASK HIM.
LUKE
BushogPapa
12-08-2004 06:18:56
You CAN put a V-8 in it...!!!! (I couldn't help myself..!!)
What a mind-blower it is, to see one with a V-8 in it...!!
Ron..
PotentPuller
12-17-2004 20:03:07
 Re: How to get more HP out of my G jd in reply to BushogPapa, 12-08-2004 06:18:56
Up hear in MN there is a guy who put a chevy 350 in a styled A. He had to lengthen the frame and he installed a right-angle gearbox off of a brushhog to connecect the engine to the tranny. Everey thing from the flywheel back is stock and it all works, even the hand clutch and pto
