electric water pump- the sequel
Mopuller
12-06-2004 19:36:04
I recently asked about a 12 volt electric water pump for my pulling tractor. I found one today at Surplus Center in Nebraska. It looks pretty much like what I was looking for and is built for continuous duty. The price was $36.95 which was acceptable. It should come in a few days. If it doesn't work I am not out much. The local bus garage can get me a school bus circulator pump (which looks very similar to what I ordered) for about $100. Thanks to all who wrote in and helped.
Mopuller
12-07-2004 07:51:19
 Re: electric water pump- the sequel in reply to Mopuller, 12-06-2004 19:36:04
I was informed today that the pump I ordered from Surplus Center was out of stock. However, an engine builder said he used RV pumps without any trouble whatsoever. So that is the route I am taking. They are reasonably priced and if they do go bad will not be expensive to replace, plus, they move a lot of water.
KBMO
12-07-2004 11:38:15
 Re: electric water pump- the sequel in reply to Mopuller, 12-07-2004 07:51:19
I am currently using the RV pump. It's not working so good for me. It doesn't move enough volume..... It also seems to quit pumping when it gets hot. I am getting by but will be changing it.
buickanddeere
12-07-2004 12:52:41
 Re: electric water pump- the sequel in reply to KBMO, 12-07-2004 11:38:15
Is the pump drawing in hot water from the engine or cooler water from the rad bottom?
AC
12-07-2004 06:30:41
DARN, THAT"S A GOOD IDEA..... ..AC
Big Al
12-06-2004 23:07:11
I have used some in the $40 area, the impellers get stiff and seize after a while of pumping hot water. After I went through a couple I broke down amd bought a moroso electric pump for a small block chevy on ebay for $80, just tapped the water ports in it to 3/4 pipe and put nipples on it and mounted it in a remote location. Works awsome with 35gpm flow, you'll never have a problem.
water pump
12-06-2004 22:00:00
Hey, can you send me the part number and where you found this? Thanks,
JDGnut
12-07-2004 10:12:43
 Re: electric water pump- the sequel in reply to water pump, 12-06-2004 22:00:00
I use a surflo pump with bronze housing and Impeller.. its a little pricey.... but good... JDGnut
