60 puller cam?
DT
12-06-2004 17:33:44
Does anyone know the dimensions for a competitive puller cam for a 60? I have a friend that can possibly grind camshafts and all that stuff at his school, so it would be relatively cheap. Any ideas out there?
stroker88
12-06-2004 17:54:11
 Re: 60 puller cam? in reply to DT, 12-06-2004 17:33:44
most of the olivers that i've worked with pulling, we haven't needed a special grind. are rules only allow 20% over on rpm's and the stock cams have been just fine. haven't worked with the 60 yet. the 66 and super66 are two different grinds, have ran both with no difference. the 77 &88 seem to do just fine with stock cams, as well as the 70. if you can get some time on a dyno and try different valve settings some times you can get some more on pull down. also tube length and shape into carb can have an effect. little things mean alot on small inch low rpm engines. good luck
