Minniapolis Moline UTU
Kevin
12-06-2004 14:00:52
Will these turn out to be ok pullers? I found one that the motor might be getting tight on and it needs 1 new rims for $500. Do you think this is worth it? Also were do i find new minniapolis moline parts? Ive been going to the case/IH dealer for farmall parts but what bout minniapolis moline?
Mopower
12-07-2004 05:01:46
 Re: Minniapolis Moline UTU in reply to Kevin, 12-06-2004 14:00:52
Kevin, yes it is worth it. Where are you located? There are several fine places to get MM parts depending on what you need. Let me know what you are after and where you are and I can give you a list of great MM folks.
Ethan
Kevin
12-07-2004 18:51:54
 Re: Minniapolis Moline UTU in reply to Mopower, 12-07-2004 05:01:46
I am in akron NY, well its actually Newstead but Newstead isnt really recognized, we dont even have our own post office, so yea, basicly akron. I will be needing a new rim...or two, but i think my IH dealer can get me that becuase they just get their rims through a "general rim place". I will also be after some motor parts or some bolt ons from larger tractors to give it that extra edge without dumping tons of cash into it. Also it is said that the motor might be getting tight, does that just mean the bearings in the crank? Will these loosen up with alittle usage?
Mopower
12-08-2004 04:47:22
 Re: Minniapolis Moline UTU in reply to Kevin, 12-07-2004 18:51:54
I've never heard of a motor "getting tight". I know they can be hard to roll over when they are dry and sit for a long time. Some sieze up with rust. If anything, a worn motor gets a little loose like my old UTU. There is a fella in NY near Buffalo. His Name is Don Rice. He has tons of MM parts. Good G parts or M5 parts can really turn up the horsepower. M5 blocks will get you 336 to 350 cubes as opposed to your original 283. A G crank or G crank with short M5 or tall G blocks will get you up to 403 or more cubes. Your stock heads will provide more compression at that point and it works out pretty good for a low dollar tractor. I have three tractors set up like this and they get good power.
