70 JD drawbar
poorerbut
01-18-2002 13:27:24
Is there any way to re-temper the draw bar
on a '70 or re-inforce it and still be able
to slide it in and out or should I try to find
another drawbar? Mine is flexing really bad in
the center position and all the way in is too
tight to turn with the big trailer.
Appreciate some suggestions. Thanks . pb
JIM FUNK
01-22-2002 15:38:35
 Re: 70 JD drawbar in reply to poorerbut, 01-18-2002 13:27:24
WE HAVE A 70 DIESL THAT WE MESS AROUND WITH AND MY DAD IS A WELDER HE BUILT ME A DRAW BAR THAT SLIDES IN AND OUT AND IS RIGHT IN THER SO IT PULLS DOWN ON THE TIES FOR TRACTION BEINGS GOT AN M AND 560 MIGHT SELL CHEAP IF YOU WHANT IT THANKS JIM
JIM FUNK
01-22-2002 15:37:41
G Taylor
01-20-2002 07:45:33
Which model is your 70 & what class? Our 70Gas rollo-matic rowcrop has no problems in the 6500lb class with the drawbar as short as possible. Front will lift at track end if traction is decent. The 70 diesel standard however needs a long drawbar to lever all the front weight up in the 8000lb class. I'm open to suggestions too. Had thought of getting a wider drawbar of modern steel & surface grinding it thinner to fit the drawbar supports?
welder
01-19-2002 09:14:01
weld a long piece of 1/2 on each side of the drawbar and move the stabilizer pins out on the bail to accomidate ..wont bend front end will go straight up first !!
welder
01-19-2002 09:13:36
Jack
01-18-2002 14:06:14
My 70 with the drawbar all the way extended does that too with a trailer but has not even bent perminatly.I had to drill a hole through mine and there is lots of metal that came out of that hole.Your front end might leave the ground before it bends.Just my.02 cents.Later Jack(TN).
