Massey 44- 6
David H
12-06-2004 03:48:36
Is anyone out there pulling a flat head six? I need suggestions. What stroke/bore combinations will really work? Thanks, David
David H
12-08-2004 03:58:04
 Re: Massey 44- 6 in reply to David H, 12-06-2004 03:48:36
Where can I find a 427? What all were they in? Thanks a ton. David
massey puller 22/44
12-07-2004 15:24:14
find you a 330 conteintal or a 427 conteintal
they are legal to run any where and there is no need to stroke or bore. the 330 and 427 came as a power units. we run one with a 330.
Agco Avenger
12-07-2004 20:31:38
 Re: Massey 44- 6 in reply to massey puller 22/44, 12-07-2004 15:24:14
Hello,
What did you do for a clutch on your 330 Cont in the 44-6? I am building a 44-6 this winter with a 427. I am planning on using the stock tractor clutch and flywheel on the 427. Will it hold? Also can someone tell me the stock gear speeds of a 44-6, were they rated at 1500 or 1800 RPM? Email if you want. Thanks, Avenger
