Wanting more out of my A
Double Thunder
12-05-2004 15:37:51
I have some extra cash that I'm going to put in into my puller. The A pulls good, but I want a little more power out of the girl.
Heres what I got:
51' JD A with a 60 block, with the 60 carb
Electronic Ignition and hotter coil on the way
creeper gear, tires: 12.4 short/long
usually pull from 5000lb to 6500lb on dirt tracks
Hooked
12-07-2004 11:37:58
 Re: Wanting more out of my A in reply to Double Thunder, 12-05-2004 15:37:51
Replace the manifold with a 60 propane manifold, by-pass the oil bath air cleaner and use a paper filter at the intake and plane the head (Maybe 200/1000ths). These will make a difference without investing big bucks.
Double Thunder
12-07-2004 12:07:35
 Re: Wanting more out of my A in reply to Hooked, 12-07-2004 11:37:58
Are those propane manifolds easy to find? I've heard a lot of guys talk about those propane manifolds.
Hooked
12-08-2004 05:40:30
 Re: Wanting more out of my A in reply to Double Thunder, 12-07-2004 12:07:35
Re: the propane manifold - you probably can get one through some of the bigger outfits that part-out tractors - Dennis Polk Equipment or 2 Cylinder Plus for example.
Padd
12-06-2004 15:59:17
What will a 60 regular block do for an A. Just curious as I have an A that I pull with and always looking for ideas?
Double Thunder
12-06-2004 17:30:44
 Re: Wanting more out of my A in reply to Padd, 12-06-2004 15:59:17
The blocks are very identical, but I do believe that the 60 was built to handle a little more stress. The block is bigger, as I had to cut my sideframes in order to fit it in. The big difference is the carbs. My 60 has a DLTX-81 Duplex. I thought I read somewhere that a the 60 had a higher redline that the A. I couldn't tell ya because I've modified my gov. Just my 2 cents.
Drew
12-06-2004 16:45:09
Absolutly nothing.
Steve Van Drimmelen
12-07-2004 12:15:24
 Re: Wanting more out of my A in reply to Drew, 12-06-2004 16:45:09
How about Murph's roller rockers?
Dennis Andres
12-07-2004 18:39:39
 Re: Wanting more out of my A in reply to Steve Van Drimmelen, 12-07-2004 12:15:24
Put a set of Murphy's rockers on stock 60,was good for 7 hp but lost some low end torque
Steve Van Drimmelen
12-06-2004 12:27:18
Dear Double:
I have about 100 hooks or so on my 51 'A'. Drop me an e-mail at [email protected] and I'll tell you what I've done and what I'm going to do next. It may help you decide how to spend your money.
Steve
JDG
12-05-2004 18:03:44
First get rid of those tires and get some good ones!
Double Thunder
12-05-2004 18:23:53
 Re: Wanting more out of my A in reply to JDG, 12-05-2004 18:03:44
Yeah, I know the tires are an issue. I was thinking of finding a pair of 15.5x38's. I know she could handle 16.9's, but they may be a little extreme.
Flogger
12-06-2004 13:06:11
 Re: Wanting more out of my A in reply to Double Thunder, 12-05-2004 18:23:53
With a creeper gear you should have plenty of vinegar for 16.9s.
