560 Diesel blows white smoke
super red
12-05-2004 06:43:36
I just rebuilt my 560Diesel when I have it running after it is warmed up it still smokes white and runs rough . it has a new head also on it . I switched pumps and it does the same .is the pump timing still off or could it be more?
ejr
12-05-2004 15:12:38
 Re: 560 Diesel blows white smoke in reply to super red, 12-05-2004 06:43:36
It sounds like you have to much advance.
been there
12-05-2004 11:16:29
my pump was 180 off but it started hard. or the other thing is a water prob. like a head or gasket maybe block. is the oil white or cream color?
super red
12-05-2004 17:33:46
 Re: 560 Diesel blows white smoke in reply to been there, 12-05-2004 11:16:29
when your pump was 180 off did it also blow white smoke ?
super red
12-05-2004 17:25:04
the oil looks good . and its not taking any water either . it has a new head also but if the pump is off would that make it smoke white ? I mean its a smoker . I hope thats all it is .
been there
12-06-2004 17:47:47
 Re: 560 Diesel blows white smoke in reply to super red, 12-05-2004 17:25:04
sounds like a timing prob. or a fuel prob. timing gear on pump or something of that sort when my pump was off it would barely start then chug out white smoke.
super red
12-12-2004 18:49:59
 Re: 560 Diesel blows white smoke in reply to been there, 12-06-2004 17:47:47
It sounds like the same thing . I usually work on the gassers this is my first 560D I set the pump to the manual but it does the same or I did something wrong . which is the simplest way to set the pump ?
Farmall H Puller
12-05-2004 15:04:32
Your rings could be stuck.
