How do you make a 53 detroit Sing
Vic
12-04-2004 17:40:51
I'm trying to build a 435JD puller. Any help would be appreciated.
PULLER
12-06-2004 04:28:33
 Re: How do you make a 53 detroit Sing in reply to Vic , 12-04-2004 17:40:51
I have a 435 that I have been pulling for 7 years. cal me RAY ,573-547-1965
720Deere
12-05-2004 19:26:26
You could probably zing as much as 75 to 80 hp out of that detroit, but the rear in that 435 will never handle it for pulling. Most of them fail at much over 35 to 40 hp!
jd puller
12-05-2004 12:03:59
think I would start by going to about a 30% overdrive on the blower and then boring it out as much as possible, turn the injector pump up and install the injectors out of a 930 case I think (dont quote me on that) and then you will need to go to larger valves to get the air in there. try in and see....new of one that had 18.4-38 on on it that would spinn them any time
Vic
12-05-2004 18:36:25
 Re: How do you make a 53 detroit Sing in reply to jd puller, 12-05-2004 12:03:59
Thanks any ideas are appreciated. I've got a set of 16.9X38 Field and Roads. Not cut yet.
