header and carb
Farmall H Pulle
12-01-2004 14:48:40
Does enyone have a pulling Carb and header fom my farmall H ????? Thank you. Farmall H Puller.
big al
12-01-2004 20:43:27
 Re: header and carb in reply to Farmall H Puller, 12-01-2004 14:48:40
I can build a header for you, but will need to know engine size, valve and port size, camshaft duration, fireing order and expected rpm range, a well engineared tuned equil length header will do more than any stroker crank ever will
FARMALL
12-01-2004 23:24:11
 Re: header and carb in reply to big al, 12-01-2004 20:43:27
Not for stock to 20 percent over rpms. A good LP
manifold or aftermarket Johnson manifold sized properly works very good. The manifold can be opened up and tapered inside to gradualy increase airspeed. Its hard to do this with tubing but not impossible(intake).
