Ford 172 Cam Question
Richard H.
11-30-2004 10:11:40
Please don"t laugh but last winter and spring I completly redid my 861. While I was rebuilbing the engine I kept thinking about splitting the cam in the center and turning it 180 degrees, welding it back together so I would have two cyl. firing at once using something like a cross- fire ignition. Possible?? Or can someone tell me where to ask this question or just tell me I am a few bricks shy..... .
POWER LOSS
11-30-2004 11:34:18
 Re: Ford 172 Cam Question in reply to Richard H., 11-30-2004 10:11:40
Just buy a JD. Ha ha, But I dont think it would run right. With a normal 4 cyl engine you always have a cyl. drawing in fuel-air mixture(constent vacuum). With the system you are propsing you would not. Would loose power. You would need double the size carb & manifold to feed equal to what you have now.
