select o speed trans in 971 fords.
crewter
11-29-2004 21:49:46
How well do the select o speeds work in the fords for pulling? What does a 971 weight?
Brad
RAY RAYMOND
11-30-2004 05:50:58
 Re: select o speed trans in 971 fords. in reply to crewter, 11-29-2004 21:49:46
GETTING PARTS FOR THE SELECT-O SHIFT ARE ALMOST IMPOSSIBLE TO FIND, IF YOU GOT A GOOD ONE --YOU HAVE A GOOD ONE IF YOU HAVE A BAD ONE YOU GOT PROBLEMS, I HAVE WORK ON SOME AND IT TOOK 3 TO MAKE ONE GOOD ONE!! LIKE THE OTHER GUY SAID FORGET IT NOW BEFORE YOU HAVE A BOAT ANCHOR IN THE GARAGE!! RAY
FARMALL
11-30-2004 04:54:31
Forget the select o speed trans.
crewter
11-30-2004 17:29:53
 Re: select o speed trans in 971 fords. in reply to FARMALL, 11-30-2004 04:54:31
thanks
