dead man throttle
mshadow77
11-28-2004 19:05:09
What is a dead man throttle? Also how do you hook up a kill switch for an Oliver 77 diesel? Mike
s88puller
11-29-2004 16:47:17
 Re: dead man throttle in reply to mshadow77, 11-28-2004 19:05:09
I pull a s88 diesel, the best way to do a kill switch is to shut off the air. To do this you will have to drill a hole in your hood and put a straight pipe off your intake. Get a rain cap and drill a hole in it and stick a pin through it and tie the pin to a cable so when the cable is pulled it also pulls the pin and the rain cap shuts and kills the air which should also kill the tractor.
770 Puller
11-29-2004 15:05:53
I use one on my 101 massey, it may save me when I get up side down. Hope that it does not happen !
ray raymond
11-29-2004 04:54:47
dead man throttle is a throttle that when your hand come off it goes bAck to idle (spring loaded that way if anything happens just let go and back to idle ) it works and should be a good item to add to any pro stock tractors. most guys have a flapper that if the kill switch is pulled the hair clip will come out and shut the air intake off. RAY
