ripped tire
minnieub
11-28-2004 15:49:51
our best set of tires had a boot in them. between pulls this summer we let them set out in the hot sun, the hole went from 3/4 inch long to over 6inches. has anyone tried volcanising tires, does it work and what is it?
dctom
11-28-2004 16:37:51
 Re: ripped tire in reply to minnieub, 11-28-2004 15:49:51
if hole is not too big and casing not rotten it can be done and works
RCP
11-28-2004 19:36:53
 Re: ripped tire in reply to dctom, 11-28-2004 16:37:51
I had a set of Armstrongs that split, I drilled holes in them and laced them like a football with parachute cord, then put big boots on the inside, they held for a couple of years of pulling until the tires were replaced.
buickanddeere
11-28-2004 20:21:54
 Re: ripped tire in reply to RCP, 11-28-2004 19:36:53
There is some "wonder glop" tire glue/cement/putty that www.millertire.com sells. If that stuff was spread all over the tear just before lacing it up, the repair maybe even stronger?
dctom
11-28-2004 16:37:46
