JD 60 LP Pistons in 60 Gas Engine???
JDVan
11-27-2004 17:50:51
Has anyone on this board had experience running regular JD 60 LP pistons in a regular JD 60 gas engine? Was the performance increase noticeable? How much HP increase? Better lugging power? Any pre-ignition knock problems? Need to go to higher octane gas? Was it worth the work to change pistons?
Bushogpapa
11-29-2004 05:45:16
 Re: JD 60 LP Pistons in 60 Gas Engine??? in reply to JDVan, 11-27-2004 17:50:51
Many "LP" 60's, 620's and 630's were converted to Gasoline over the years... They should work well...the compression is over 8:1 so the timeing has to be set well, to prevent pre-ignition or knocking... Regular gas (87) should work. Other than more compression, Hard valve seats and a true Cold Intake...there is no difference between a gas and LP..
