460 or 560 modified stock puller
Dickie
11-25-2004 15:20:59
Does anybody hav a 460 or 560 puller for sale. If so, How much $.
j-p-y 1066
11-28-2004 15:28:13
 Re: 460 or 560 modified stock puller in reply to Dickie, 11-25-2004 15:20:59
we got a 460 - 301 fuelinjected on alky ,turboed steal flywheel 2 disc clutch, urmson tranny, girdel, hard blocked , no water, steal centers in bullgears, big imput shaft, fast constant mesh gears , been setting 4 years, 5grand
460
11-28-2004 13:05:04
i have a 460 roller. it has to go bulit new tractor last year. the block is cracked but all parts are good if you want motor parts. the roller is a 460 fast ring and pinion slow 4th, rack and pinion steering, weld on hubs, willie bars, adj hitch, alot more to list. the tractor is about #4400 bare with me on it. the motor parts are all here. the cid was aroud 350, still have stroked crank, 2 cams, 2 intake 1 custom 1 lp, headers, ported and polshed head, pistons,rods,well everything to make it go. like i said the block is cracked but have a stock 301 sitting here ready to get bored out if your interested in any thing e-mail me thanks.
Eric Stephen
11-29-2004 08:37:32
 Re: 460 or 560 modified stock puller in reply to 460, 11-28-2004 13:05:04
Hey "460" owner that has parts and tractor for sale, please give me a e-mail, I am interested in what you have. thanks Eric Stephen e-mail address is [email protected]
Eric Stephen
11-28-2004 14:08:23
Dickie, please e-mail me, I am interested in what you have to sell. Eric Stephen E-mail address is [email protected] thanks
Michael Earnest
11-26-2004 19:43:22
I have a 460 puller project started. I took all of the hyd, pto, etc out. It has 18.4*38 on pressed steel, wheelie bars. The tranny is good, not sure about the t/a. It has a 263 motor in it(no head). I have a rd 501 cu in truck moter that I was going to put in it, it seems to be good. The sheet metal is all good and straight. I was asking $3500. Email me or call at 806-456-7759.
LumbrJakMan
11-26-2004 10:09:35
I have a 1959 Farmall 560 with a wide fornt . Its prety much all stock . It runs well.No cracks or welds , Tranny is fine . T/A works well. and pulls very well. I do stock Pulling here in New Hampshire . I have it down to 6500. Good rubber all around, brand new seat, Making room in the barn for winter , Asking 3800.00 Give me a holler if you want some pics
Reedy
11-26-2004 09:41:13
Have a 460 with a 301. Just went through top end. Has pressed steel 18.4-38 Firestones, tubing ft axle,rack & pinion but have original. Should make 4500#. In process of a facelift. Needs finishing touches and paint. $5500
alan schlagenhauf
11-25-2004 17:49:50
I have a 1959 IH 560 I would sell. It has a 301 enigne with 1/2 stroke on crank. It has 125 hp plus. Can get it down to 5500 class. Can reach me at 260 334 5524.
puller 2
11-25-2004 16:35:28
got a super farm 560 LP motor on gas. fresh rebuild on 660 carb. no pto or hyd, modified powr steering(lighter). runs great from 2000 to 3000rpm... call or email for details should be at princeton in on sunday
curt smith 217 826 6198 [email protected]
Red Puller
11-26-2004 12:41:36
 Re: 460 or 560 modified stock puller in reply to puller 2, 11-25-2004 16:35:28
Dickie, I have a 1959 farmall 460 with completely rebuilt 301 propane engine. Propane head has had extensive porting and bench flow work, bigger valves, heavier springs. New large Impco carb and regulator, electronic ignition, Hy capacity T/A and clutch. Front, side, and rear weight brackets, adjustable wheelie bars, adjustable pulling hitch. 18.4x34 firestones on 20" rims. Pulls 5000# and up. 125+hp. $5600. Give me a call, I will send you some photos if interested.
231-263-2632 Wayne
