Questioin for ChadS
john marlowe
11-25-2004 11:00:15
We have a Farmall 300 that we are going to rebuild and pull with, but we have some questions. We are not going to through a lot of money at this 300 but we want every dime to go as far as it can. will 350 pistons and sleeves go into the 300 block with out any problem? If so what type/brand, of piston/sleeve kit do you recommend? We plan on using the stock head, any suggestions on what we could do with it ? At your advice, I put one of your gov. springs in my 1950 M, and adjusted it up, -I was really pleased. I would like to do the same to my H and this 300. With your spring in my H what RPM could I safely adjust my gov. to? Also what would it be for the 300? I hear that some will run no sleeves ,is this advisable ? Thanks for you help. John
ChadS
11-25-2004 14:42:24
 Re: Questioin for ChadS in reply to john marlowe, 11-25-2004 11:00:15
20%over rpm easily. Yes the 169 can take the 175 sleeves, no boring, the 169 barrel is the same size as the 175. Use H rods in it and a bit of machine work and can pick you up quite a bit, bout the same output as if you bolted on an LP head. Just offset the wrist pin bushing on the H rods, wit the small pin 350 piston, re machine the pistons for the compression height, and pick up a whole lot of dome on the piston. Wit this set up capable of 55+hp out of a 175ci. Just gotta get the compression up around 9to1, or 10 to 1. ChadS
