make a wd45 a puller where to start?
mjamison OH
11-25-2004 07:30:04
my local pulls say must be stock appearing,and allowed cut tires. So what tire and rims do I need what engine modifications do I need to make? Where do I find some small light wieght rims for the front wheels that will fit a wd45? Looking to spend about 2500$ this winter to make it more competitive.
CA+
11-28-2004 16:49:31
 Re: make a wd45 a puller where to start? in reply to mjamison OH, 11-25-2004 07:30:04
NEED 250 TO 280 CID MOTOR WILL PULL 3700UP TO 7200
STOCK AND WIN ASK ROUND MAN :RMWSD;
rmwsd
11-25-2004 15:35:05
what weight classess are you planning on pulling is it a super class puller or just cut tires
mjamisonOH
11-26-2004 12:41:59
 Re: make a wd45 a puller where to start? in reply to rmwsd, 11-25-2004 15:35:05
I would like to pull in a super class & a percentage tug pull.
wdpuller
11-25-2004 18:48:28
it depends on how deep you want to get on this you can build a big hp or you can just tinker untill you are happy on how it is running and inproving as as you get extra $$ to spend on it
mjamisonOH
11-26-2004 12:48:59
 Re: make a wd45 a puller where to start? in reply to wdpuller , 11-25-2004 18:48:28
Tell me were to get started. I pulled this year (my first year) completely stock and pulled as high as 217% at a tug pull. the only thing i have done to tractor is put a pulling hitch and wieght brackets on it.
Wc man
12-04-2004 18:11:13
 Re: make a wd45 a puller where to start? in reply to mjamisonOH, 11-26-2004 12:48:59
To help it cheap try chevy rat ex valves in intake. try Ford 460 smog pistons. flat head dodge rods. 5.5 stroke or 5.75if you want to grind use 4020 JD sleves. just get used ones put them in, then bore them. use a good machine shop, not a car place. don't worry about sealing them on the bottom. just pour a can of K&N block sealer in before you put the head on. Also I would dowell pin the manafold. so you get it on right.
mjamison oh
12-12-2004 15:18:51
 Re: make a wd45 a puller where to start? in reply to Wc man, 12-04-2004 18:11:13
wc man what kind of dodge rods, what size motor are the out of? do I have to grind the crank? the chevy rat ex valves where would i locate these are they in a certian motor or do I buy them new at a parts house? I don't know what you mean by dowel pinning the manafold won't it just bolt on?
